pegagu
Aug 28, 2018Aspirant
RN102 power led blinking constantly
Hi,
My RN102 power led is constantly blinking and I have no access to the drives nor the webadmin page.
If I eject the drives out and I power on the device again the system boots and I can access the webadmin page, so I insert back again which are recognized but they are shown as full (which they shouldn´t) and not accessible.
I have read across the forum some similar errors and it looks the moderator ended up loging into the system to reinstall some packages.
anyhelp and suggestions are more than welcome
thanks
pere
Did you reboot your NAS? my remote acess is disconnected.
Did you install two disks on NAS? I find a disk's partition is wrong, sda has sda1 and sda5, it is wrong, it should be sda1,sda2 and sda3,
Is the disk from another device?
sdb is USB disk,
sdc is another disk which partitions are OK (sda1, sda2 and sda3) Could do you please enable remote mode again and tell me debug code?
- evan2NETGEAR Expert
Which FW version the NAS is running?
It support safety mode on 6.9.3+, if remove disk, then power on NAS, it boot into safety mode, the OS is running in RAM,
if Power on NAS with disk installed, OS is running on Disk,
it seems OS has problem on Disk (boot paratition),
Can RAIDar detect this NAS?
Please download logs if RAIDar can detect it.
- pegaguAspirantThanks evan2, unfortunately RAIDar is not detecting the device, ReadyCloud is but I guess that's not helping.
I submitted the system logs though.
Thanks
P
