pegagu
Aug 28, 2018Aspirant
RN102 power led blinking constantly
Hi,
My RN102 power led is constantly blinking and I have no access to the drives nor the webadmin page.
If I eject the drives out and I power on the device again the system boots and I can access...
- Aug 30, 2018
Did you reboot your NAS? my remote acess is disconnected.
Did you install two disks on NAS? I find a disk's partition is wrong, sda has sda1 and sda5, it is wrong, it should be sda1,sda2 and sda3,
Is the disk from another device?
sdb is USB disk,
sdc is another disk which partitions are OK (sda1, sda2 and sda3) Could do you please enable remote mode again and tell me debug code?
JohnCM_S
Aug 28, 2018NETGEAR Employee Retired
Hi pegagu,
Can you download the system logs and then send it to us? You may check this link on how you can send it.
- evan2Aug 29, 2018NETGEAR Expert
Which FW version the NAS is running?
It support safety mode on 6.9.3+, if remove disk, then power on NAS, it boot into safety mode, the OS is running in RAM,
if Power on NAS with disk installed, OS is running on Disk,
it seems OS has problem on Disk (boot paratition),
Can RAIDar detect this NAS?
Please download logs if RAIDar can detect it.
- pegaguAug 29, 2018AspirantThanks evan2, unfortunately RAIDar is not detecting the device, ReadyCloud is but I guess that's not helping.
I submitted the system logs though.
Thanks
P - pegaguAug 29, 2018Aspirant
oops, in reply to evan2 , I forgot to say the firmware is indeed 6.9.3. and RAIDar is not detecting the device
- evan2Aug 30, 2018NETGEAR Expert
Tt boot into safety mode when power on NAS without disk,
then insert disk again, volume doesn't be mount, because OS is running in RAM now,
You may enable diagnostic in safe mode, and PM me 5 debug code.
enable secure diagnosticn in NAS admin GUI =>System=>Settings=>Support
