pegagu's avatar
pegagu
RN102 power led blinking constantly
Hi, My RN102 power led is constantly blinking and I have no access to the drives nor the webadmin page. If I eject the drives out and I power on the device again the system boots and I can access...
  • evan2's avatar
    evan2
    Aug 30, 2018
    Did you reboot your NAS? my remote acess is disconnected.
    Did you install two disks on NAS? I find a disk's partition is wrong, sda has sda1 and sda5, it is wrong, it should be sda1,sda2 and sda3,
    Is the disk from another device?
    sdb is USB disk,
    sdc is another disk which partitions are OK (sda1, sda2 and sda3) Could do you please enable remote mode again and tell me debug code?
ProSupport for Business
