yycjohn
Aug 17, 2017Aspirant
RN102 TFTP_REQ
Hi, I've been running my RN102 for a few years with no trouble. It prompted me for a FW update to 6.8.0 so I said ok. Now the unit appears to be stuck in boot and when I run RAIDar the status sa...
- Mar 22, 2018Looks like the internal flash in this unit may be failing.
I created a smaller filesystem on the internal flash and it looks like this was successful. Please confirm.
Your system has been rebooted back to normal mode.
Marty_M
Aug 23, 2017NETGEAR Employee Retired
Hello yycjohn,,
If https://ip.address.of.nas/fwbroker will not work, the concern may require assistance from the engineers and/or higher tier who can remote in to the NAS and fix this from the backend.
Marty_M
NETGEAR Community Team
- StephenBAug 23, 2017Guru - Experienced User
You might also try disconnecting all your USB devices (including the UPS) and then boot.
- mdgm-ntgrAug 27, 2017NETGEAR Employee Retired
Did these suggestions resolve the problem?
If not you could try booting off USB into a special tech support mode. I can provide instructions on how to do that.- mdgm-ntgrMar 22, 2018NETGEAR Employee RetiredLooks like the internal flash in this unit may be failing.
