yycjohn
Aug 17, 2017Aspirant
RN102 TFTP_REQ
Hi, I've been running my RN102 for a few years with no trouble. It prompted me for a FW update to 6.8.0 so I said ok. Now the unit appears to be stuck in boot and when I run RAIDar the status sa...
- Mar 22, 2018Looks like the internal flash in this unit may be failing.
I created a smaller filesystem on the internal flash and it looks like this was successful. Please confirm.
Your system has been rebooted back to normal mode.
mdgm-ntgr
Aug 27, 2017NETGEAR Employee Retired
Did these suggestions resolve the problem?
If not you could try booting off USB into a special tech support mode. I can provide instructions on how to do that.
mdgm-ntgr
Mar 22, 2018NETGEAR Employee Retired
- yycjohnMar 22, 2018Aspirant
That looks like it worked, Thank you.
To prevent this from happening again (if the internal flash is failing) I was wondering if you could answer a couple questions?
If the internal flash fails completely what will that effect?
Does the unit use the internal flash for anything other than reinstalling the OS?
If I keep it on this firmware (6.9.3)(no updates) will that help?
Thanks
John
- mdgm-ntgrMar 22, 2018NETGEAR Employee RetiredThe internal flash is also used for the early part of the boot process before handing things over to the disks. Without it the NAS won’t boot. The boot menu options use the internal flash.
