Benpar
Jul 31, 2020Aspirant
RN10200 not connecting to sagemcom f@st 5366
I am having an issue with my RN10200 with a new modem router, Sagemcom F@st 5366 supplied with my new service. The NAS will not communicate with router. No communication lights flash when plugged in, ...
Aug 01, 2020Guru - Experienced User
Are you sure the ethernet ports in the sagemcom work? (are you able to test them with another device?).
- BenparAug 01, 2020AspirantYes, i have a security camera system that is working and i have confirmed it works in every port
- StephenBAug 01, 2020Guru - Experienced User
Benpar wrote:
Yes, i have a security camera system that is working and i have confirmed it works in every portOk.
Have you tried both ethernet ports on the NAS?
It might be worth seeing if RAIDar can find the NAS. https://kb.netgear.com/20684/ReadyNAS-Downloads Sometimes the NAS is connected properly to ethernet, but isn't getting a DHCP address.
Do you have a switch you can put in between the NAS and the router? If the router has "green ethernet" features, then it is conceivable that is interfering with the ethernet autonegotiation.
- BenparAug 01, 2020AspirantThere is only one ethernet port on the RN10200.
RAIDar does not find the NAS.
I don’t have a switch, but will try as soon as I can.
