Tim2020
Jun 22, 2020Aspirant
RN10200 won't boot-up
Hi, I've an approximaly 2004/05 RN10200 ReadyNas model. Since last night it won't power off and boot properly. So when I pull out the power plug the NAS is, obvisouly, powered down. As soon...
Tim2020
Jun 23, 2020Aspirant
Hi Sandshark,
thanks for the reply.
I will try a non USB3, somewhere I do have an ancient USB1 drive.
RAIDar didn't find the NAS, neither did a regular networscan.
Sandshark
Jun 23, 2020Sensei
That does point to a Flash/UBOOT issue. Definately try the USB recovery again with a non USB3 device. If it has an access LED, all the better. The LED should do more than a quick flash.
- Tim2020Jun 23, 2020Aspirant
I tried different USB sticks.
With the USB1.0 I did see interaction, and it powered down when finished.
Although it didn't fix the problem. When powered on, it goes back to the problem.
All the leds are on, even when there are no disks inside. When I press the backup button, all led goes out except the power button.
I tried an USB2.0 stick, there was some interaction.
But the power and backup leds were constanly blinking, including the led on the USB.
I guess it couldn't read the stick and got stuck on it.
