Gazmeans
Aug 02, 2025Aspirant
RN10211D flashing power light
Hi. I have a now (for some time now!) EOL RN102 which foolishly I am still using. I powered it off/on today and subsequently the power light now repeatedly flashes twice and pauses. On searching for ...
Gazmeans
Aug 03, 2025Aspirant
Many thanks for the comprehensive reply Mark. I can confirm what you say about the RAM - having removed the motherboard to look for it and finding it wasn't there! Having put it all back together I still have the same 2 flashes then a pause of the power button happening. From your list of codes it would seem that means it's not detecting the disks? I'll have a look for a replacement unit and/or power supply perhaps.
