LandoSan's avatar
LandoSan
RBS20 bricked? red power led flashing
had an old pair of RBS20 satellites with red power led flashing
won´t connect to router
removed them
bricked?
searched a lot
what worked for me
  1. removed satellites from router
  2. updated router to last firmware version
  3. download and unpacked satellite firmware version (same version as router)
  4. connected the satellite by ethernet cable to router (RBR20)
  5. changed router address (it was 192.168.1.1), changed to 192.168.1.200
  6. used software TFTPD32, connecting to the interface where router was connected
  7. uploaded the firmware to 192.168.1.1 (this goes to satellite, through router!)
  8. that is all... repeat with other satellites
  9. then add the satellite back to router using web interface!
  • According to FURRYe38 suggested... marking it as solved...
    solution built with info collected in several different posts, and some guesswork...
