j-o-h-a-n
Mar 13, 2023Aspirant
RN104 /// RAID1 /// 4xHDD /// 1 VOLUME
Chees! I'd like to reconfigure my RN104 with 4 brand new 4TB HDD (from WD). Preferable in RAID 1 and as one large volume. This should be possible, right? I have tried and tried but I could not find...
- Mar 14, 2023
j-o-h-a-n wrote:
A). Two parallel RAID 1 volumes 2x4TB + 2x4TB (= approx. 7,5TB?)Volume size for each volume would be 4 TB, so 8 TB total. The NAS (like Windows) reports size in TiB (1024*1024*1024*1024 bytes), and 8 TB is the same as ~7.25 TiB.
A variant is to set up a single 2x8TB to start with, and add a second volume later on. Four 4 TB drives are about the same cost as two 8 TB, and with RAID-1 you get the same amount of storage. But you'd also have 2 free slots, so the first expansion wouldn't require replacing working disks.
With this approach, you'd create some shares on each volume. You'd see the full share list from Windows, and normally users wouldn't know (or care) which share is on which volume. As administrator, you would need to keep a reasonable amount of free space on both volumes. You sometimes could shift a share from one volume to the other to roughly balance free space.
Expansion of the two volumes could be done independently, and you would need to upgrade both disks in the volume to the larger size in order to expand.
One benefit of RAID-1 is that data recovery is fairly simple, since the data is mirrored on both disks. So each disk has a complete copy of the data.
That said, RAID is not enough to keep your data safe, so you should also put a backup plan in place for your data. Using one or more USB drives is a popular option.
j-o-h-a-n wrote:
B). One RAID 5 volume 4x4TB (approx. 12 TB?)If you choose this mode, just stick with the default X-RAID - it manages the RAID setup for you. With "classic" RAID-5, all the disks would need to upgraded to a larger size when it is time to expand. X-RAID supports unequal drive sizes, and would allow you to upgrade less expensively. Note X-RAID uses standard software RAID underneath, it is just a management package.
Size would be 12 TB (10.9 TiB) - the general capacity rule is "sum the disks and subtract the largest".
This approach gives you the most capacity possible with single redundancy (handling one disk failure with no data loss).
With X-RAID, the first expansion would require upgrading a pair of disks - for example, expanding to 2x8TB+2x4TB. Capacity would then grow to 16 TB. You could then upgrade a single disk later on (3x8TB+4TB), increasing capacity to 20 TB.
Data Recovery (if ever needed) would require at least three disks to be accessible at the same time, so it is more complicated than A). That said, if you put a good backup plan in place, you aren't likely to ever need data recovery. And no matter what approach you take, data recovery is expensive, and not always successful.
Mar 13, 2023Guru - Experienced User
j-o-h-a-n wrote:
. Does anyone know how to create one large RAID 1 volume from 4x4TB HDD?
Why do you want that? It would give you a 4 TB volume size.
The default RAID-5 would give you 12 TB with RAID redundancy.
RAID-0 would give you 24 TB, but as Sandshark says, is is not a good mode unless you are very well backed up. Any failures will result in losing all your data.
- j-o-h-a-nMar 14, 2023Aspirant
Thanks! Yes slowly I start to understand 🙂
From my horizon and your input above I see two main alternatives.
RN104 and 4pcs 4TB HDD =
or
If I'd try not to apply my Cro-Magnon theories both alternatives above should be quite safe and have OK performance, right? Any recommendations/advice besides the obvious difference regarding TB?
Please correct me and if someone prefer other RAID alternatives for my RN104 as above (my HDDs are still empty) please let me know.
This has shown to be a really generous and great forum! I'm not spoiled to that! Actually, you saved my day!- StephenBMar 14, 2023Guru - Experienced User
- j-o-h-a-nMar 20, 2023Aspirant
Thank you for your extensive answers!
I choosed alternative B)
One RAID 5 volume 4x4TB X-RAID
(Yes, I'll have to have also som secondary back up, hopefully in another physical space).
Resync in progress 🙂 Right now I can't really access the NAS-folders besides from the ReadyCLOUD interface. I guess it'll be different after resync / rebuild in a couple of days. Right now I have only some demo folders, until I feel confortable.
Again - thanks!
