shredder56
Oct 10, 2015Aspirant
RN104 6.4.0 USB Disk becomes unavailable due to NAS Hang.
Just upgraded to 6.4.0. I use a USB Drive as a share on my Network. Since upgrading a few days ago, I have noticed that I intermittently lose access to the USB Drive, and on inspection I see that t...
Skywalker
Nov 23, 2015NETGEAR Expert
It looks like the NTFS driver (which we license from Paragon) has begun writing full-second resolution timestamps to disk, rather than 100ns resolution. I'm inquiring with them about this.
jon_iz
Dec 06, 2015Tutor
Skywalker wrote:It looks like the NTFS driver (which we license from Paragon) has begun writing full-second resolution timestamps to disk, rather than 100ns resolution. I'm inquiring with them about this.
Hello Skywalker.
L3 support suggested I update to latest release 6.4.1, as this should cure the problem.
Following this, I can confirm the following:
Initial (full) backup of 0.91TB of data took 15 hours (longest so far)
Subsequent incremental backups took 6:05hrs and 5:16hrs respectively, so incrementals are now back to what they were prior to 6.4.0.
However, I would still question if the backup is doing correct analysis for deciding which files to copy, as I know on both of the incrementals, there is less than 2GB of changed files, in the whole of the 910GB volume being backed up...
Thoughts? Paragon driver still to be updated?
