shredder56
Oct 10, 2015Aspirant
RN104 6.4.0 USB Disk becomes unavailable due to NAS Hang.
Just upgraded to 6.4.0. I use a USB Drive as a share on my Network. Since upgrading a few days ago, I have noticed that I intermittently lose access to the USB Drive, and on inspection I see that t...
jon_iz
Oct 24, 2015Tutor
I'd already responded to the support team and noted the file security tab issues in an earlier email.
BrianL2
Oct 25, 2015NETGEAR Employee Retired
Hi jon_iz,
Just update this thread again once you receive an update or a fix from our support team.
Kind regards,
BrianL
NETGEAR Community Team
- dweinshelOct 27, 2015Tutor
Same issue w readynas 104 and is 6.4.0
2 previously working sub 3.0 drives are preventing nas boot
front sub port recognizes ups
is there a fix?
- BrianL2Oct 27, 2015NETGEAR Employee Retired
Hi dweinshel,
Can you confirm if these external hards drives that used to work are portable and USB powered? Have you tried a different one with an external power supply? I've also sent you a PM for further instructions.
Kind regards,
BrianL
NETGEAR Community Team- diwakarNov 01, 2015Aspirant
The change to 6.4.0 has been really a disaster. It's probably not a good sign if Win10 looks good in comparison.
All my backup jobs just stopped working, so I had to re-start them. Unfortunately, the RN102 doesn't recognize my USB disk (connected to back lower port) anymore: an attempt to run backup job says " cannot be mounted". OK, so I try to reformat the drive, and ReadyNAS comes back with "external storage device Expansion_Desk is busy; try later". No idea at all how it got the name "Expansion_Desk", FYI but I thought I'd mention this if it was valuable information. It also says "Format started" but nothing seems to happen. The files themselves in the external drive are accessible - I can go to "shares" and see the sub-directories etc. FYI I succeeded in reformatting my portable HDD on the back top USB port and managed to back up to that disk - I keep that in my office (separate location) and bring it home once a month for backing up. So at least I have a second copy albeit it is going to slowly go out of date over the course of November.
I also tried to take the external drive to format it via my laptop directly, that didn't work (can't remember if I'd formatted it in NTFS / FAT32 originally). Your suggestions are appreciated, as backup is one of THE reasons that people get a NAS system!
BTW, why all the PMs? Are the fixes / suggestions not stable enough for broader release?
Thanks for any help,
Diwakar
