Asha3110
Jul 18, 2020Aspirant
rn104 currently 3 x 3tb, how to increase hdd size to 3 x 6tb without losing data
HI, I currently have an rn104 with 3 x 3tb wd red HDDs. i could add another 3tb for extra storage, but i am thinking of future proofing the storage, what are the options for increasin the hdd...
Jul 18, 2020Guru - Experienced User
Asha3110 wrote:
how do you add larger hdds and transfer data?
First, you should have a backup plan for your NAS. RAID alone isn't enough to keep your data safe - and your volume isn't redundant when you are expanding your storage.
On the mechanics: To increase the space you need to have at least two of the larger disks. You don't need to upgrade all three to the same size.
If you want to end up with four disks in the array, you can hot-insert (NAS running) the first 6 TB drive in slot 4. After that resyncs, you can hot-swap disk 3. That will resync twice (the second expansion will use the "extra" space on the 6 TB disk). FWIW, 2x6TB + 2x3TB would give you the same space as 3x6TB.
If you actually want 3x6TB, then you can't use the empty slot. Instead hot-swap the disks one at a time, and make sure the resync is completed before moving on to the next.
Asha3110 wrote:
Also, if i were to purchase an upgraded nas ... how easy is it to transfer data from one to the other
You can just migrate the disks. Though I do recommend putting in a scratch disk in the new unit first, and then upgrade the software to the current version. Then power down, and move the disks over (ideally keeping them in slot order).
Asha3110
thanks for the speedy response.
so, i would need 2 x 6tb hdds? or could i buy one now and add it and continue to use the nas, and then in a few months add a second 6tb?, which raid would i need to set to do this, as when i use the hdd calculator set on raid 5, it always uses the smallest hdd size to dictate the other disk sizes,
How superior is the rn214 to the rn104? i am able to stream 4k to smart tv with the 104, would the 214 be capable of streaming to 2 tvs? i am also able to stream 1080 to to 3 smart tvs without hitch. all in all i am happy with the 104, i just don't want to run out of storage, and don't think adding another 3tb will offer me enough for years to come.
you mention a backup plan? what do you suggest?
- SandsharkJul 19, 2020Sensei
Since you only have one RAID5 volume, I don't know why you are controlling the RAID mode manually. XRAID would have set it up as RAID5 and would do the necessary expansions for you. If the current drives are all the same size you started with, you should be able to switch to XRAID now.
You can put in one 6TB now, but the additional storage will be unused. With XRAID, when you add the second 6TB, then you'll get a single volume with a 3TBx3 RAID5 layer and 2x3TB RAID1 layer. If you change the last 3TB to 6TB, then the 3x3TB layer will grow to a 3x3TB RAID5. I'm not sure that same expansion is available in FlexRAID.
- StephenBJul 19, 2020Guru - Experienced User
XRAID is the easiest. If you have a green stripe on the XRAID control on the volume page, then you are already using it. If you don't see that control, then try clicking on it - it should enable, and the stripe will then appear.
XRAID will automatically expand the volume. The capacity rule is "sum the disks an subtract the largest". So you do need at least 2 of the larger disks to use all the space on them.
Consider getting two bigger disks than 6 TB then. Perhaps 8 or 10 TB.
The least expensive is to back the NAS up to USB drives. If you do decide to upgrade to a more capable NAS, you can also re-purpose your RN104 as a backup.
The RN214 is faster - capable of saturating gigabit ethernet (sustained transfers over 100 MB/sec). The RN104 generally does around 50-70 MB/sec. It also has a lot more memory, which would be advantageous if you use plex. The RN214 also can do some real-time transcoding (1080p to SD). The RN104 can't do any real-time transcoding.
Of course the x86 ReadyNAS (RN42x, RN52x, RN62x) are also potential upgrades.
