lawriebuck's avatar
lawriebuck
RN104 'Fan System in enclosure Internal speed is below threshold. (0 rpm)' message
Hey all,   This morning on my RN104 I got the error message "Fan System in enclosure Internal speed is below threshold. (0 rpm)", However the fan is running flat out, sounding almost like a hair dr...
  • Sandshark's avatar
    Jul 30, 2020
    It sounds like the tachometer signal from the fan isn't working.  Obviously, use warranty replacement if that's an option.  Otherwise, hopefully, it's the fan itself and a fairly easy fix by replacing it.  If it's the monitor circuit, there's nothing you can do save add a "pad" that lowers the fan speed (but does nothing to correct the NAS's ability to monitor or control the speed).
ProSupport for Business
