mpilihp
Jan 06, 2023Follower
RN104 message Data Degraded - How to determine which drive is failed.
Hello I am not new to having the NAS, RN104 but new to this forum. Its worked flawless till this issue. As I stated it saying data is degraded. When I look at the system page, volume tab it sho...
Jan 09, 2023Guru - Experienced User
Look in disk_info.log
That will let you map the physical drives and slot numbers with sda, sdb, sdc. And of course you'll be able to see which one is missing.
The drive bays are numbered left to right - some of the logging goes 0-3, some is 1-4, so be careful about that.
