jpassov
Apr 11, 2019Aspirant
RN104 NAS taking forever to ReSync after Hot Swap of bad drive
I hot swapped a drive in my RN104 NAS. Everything worked and it began resyncing the RAID. After 2 days, it's only at 5.21%. Any ideas why it is taking so long? A friend has the same NAS and his onl...
Apr 11, 2019Guru - Experienced User
What was the disk configuration?
Have you checked the disk health of all the drives?
- jpassovApr 11, 2019Aspirant
(4) 2TB drives- RAID
3 other drives are showing healthy
At this pace, I may just hook up an external drive and back everything up and then start over.
- StephenBApr 11, 2019Guru - Experienced User
jpassov wrote:3 other drives are showing healthy
Don't rely on the green status on the admin page. Look at the details of the smart stats for all four drives (for instance, download the log zip file and look in disk_info.log).
Backing up your data is a good idea, as it is at risk when you do a resync.
Device: sde
Controller: 0
Channel: 0
Model: WDC WD3000FYYZ-01UL1B0
Serial: WD-WCC130273410
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
PoolHostId: 2fe5116e
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 40
Start/Stop Count: 6
Power-On Hours: 55
Power Cycle Count: 6
Load Cycle Count: 0Device: sdc
Controller: 0
Channel: 1
Serial: WD-WCC130320710
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 42
Start/Stop Count: 39
Power-On Hours: 35646
Power Cycle Count: 39
Load Cycle Count: 9Device: sdb
Controller: 0
Channel: 2
Serial: WD-WCC130000367
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 36
Reallocated Sectors: 5
Reallocation Events: 5
Spin Retry Count: 0
Current Pending Sector Count: 11
Uncorrectable Sector Count: 12
Temperature: 41
Start/Stop Count: 32
Power Cycle Count: 32
Load Cycle Count: 10Device: sda
Controller: 0
Channel: 3
Serial: WD-WCC130293212
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 38
Start/Stop Count: 33
Power Cycle Count: 33
Load Cycle Count: 12 - jpassovApr 11, 2019Aspirant
Device: sde
Controller: 0
Channel: 0
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 40
Start/Stop Count: 6
Power-On Hours: 55
Controller: 0
Channel: 1
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 42
Controller: 0
Channel: 2
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 36
Spin Retry Count: 0
Temperature: 41
Controller: 0
Channel: 3
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 38
Device: sde
Controller: 0
Channel: 0
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 40
Start/Stop Count: 6
Power-On Hours: 55
Controller: 0
Channel: 1
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 42
Controller: 0
Channel: 2
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 36
Spin Retry Count: 0
Temperature: 41
Controller: 0
Channel: 3
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 38
Looks like one of my drives has some errors:
Device: sdb
Controller: 0
Channel: 2
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 36
Spin Retry Count: 0
Temperature: 41
Load Cycle Count: 10 - jpassovApr 11, 2019Aspirant
Looks like one of other drives has some errors:
Firmware: 01.01K01
Class: SATA
RPM: 7200
Sectors: 5860533168
ATA Error Count: 36
Spin Retry Count: 0
Uncorrectable Sector Count: 12 - jpassovApr 11, 2019AspirantLooks like one of other drives has some errors: Model: WDC WD3000FYYZ-01UL1B0 Firmware: 01.01K01 Class: SATA RPM: 7200 Sectors: 5860533168 ATA Error Count: 36 Reallocated Sectors: 5 Reallocation Events: 5 Spin Retry Count: 0 Current Pending Sector Count: 11 Uncorrectable Sector Count: 12
ATA Error Count: 36
Spin Retry Count: 0
