Lesage
Apr 27, 2019Aspirant
RN104 OS695 unable to send alert messages
Hello,
Since May, 2018, my RN104 is unable to send alert messages.
Formerly, this was working well.
When using the "Send message" test, I get a pop-up window which says : "Unable to send me...
schumaku
May 14, 2019Guru - Experienced User
Some insights - access your ReadyNAS by ssh and the root account (has to be enabled) using the admin password.
The SMTP config is held (this hasn't changed for a while when I have it right) in /etc/msmtprc
# cat /etc/msmtprc
... (don't post to much - coan contain real email and password details)
The email notification systems does log to /var/log/frontview/msmtp.log so (successful only?) messages are logged here
# cat /var/log/frontview/msmtp.log
Most easy one ot start investigating is using
# sendmail -i [emailaddress]
test
(emtpy line!)
(empty line!)
CRTL-D
(emtpy line!)
(empty line!)
(empty line!)
root@RN628X:~# sendmail -i towhateeremailaddress@wherever.test
sendmail: envelope from address email-for-authentication@domain.demo not accepted by the server
sendmail: server message: 535-5.7.8 Username and Password not accepted. Learn more at
sendmail: server message: 535 5.7.8 https://support.google.com/mail/?p=BadCredentials q19sm2009370eja.59 - gsmtp
sendmail: could not send mail (account default from /etc/msmtprc)
Ok, I've used a "real" email hosted at Google, and they are informative - for this demo I had chaged the config file manually.
The required configuration for orange.fr is here (when I have it right):
Outgoing Mail Server
Account Type: SMTP
Username: Your email address is your username
Server hostname: smtp.orange.fr
Server port: 465
Authentication: Password
SSL/TLS: Yes
- LesageMay 15, 2019Aspirant
Thank you for the response
I understand that you suggest to connect to the ReadyNas through an SSL connection from another (distant) computer, then inspect the log file, which is hidden in the root account. Of course, access to this root holder/file should be enabled beforehand.
Do you mean that the log file is unaccessible from Windows Explorer upon my Windows10 PC ?
I have checked the configuration for the outgoing mail server : it is correct
Best regards
- schumakuMay 16, 2019Guru - Experienced User
Sure ... SSH it is, yes and yes.
However it does not work ...
- LesageMay 16, 2019Aspirant
However...
If I connect (inside OS695) through my Microsoft or Google account,
I receive messages (in my Outlook mailbox) from Microsoft or Google, telling that ReadyNas has been given access to my mailbox
But ReadyNAS is still unsuccessful at sending the test message ...
Best,
