Lesage
Apr 27, 2019Aspirant
RN104 OS695 unable to send alert messages
Hello,
Since May, 2018, my RN104 is unable to send alert messages.
Formerly, this was working well.
When using the "Send message" test, I get a pop-up window which says : "Unable to send me...
Lesage
May 15, 2019Aspirant
Thank you for the response
I understand that you suggest to connect to the ReadyNas through an SSL connection from another (distant) computer, then inspect the log file, which is hidden in the root account. Of course, access to this root holder/file should be enabled beforehand.
Do you mean that the log file is unaccessible from Windows Explorer upon my Windows10 PC ?
I have checked the configuration for the outgoing mail server : it is correct
Best regards
schumaku
May 16, 2019Guru - Experienced User
Sure ... SSH it is, yes and yes.
However it does not work ...
- LesageMay 16, 2019Aspirant
However...
If I connect (inside OS695) through my Microsoft or Google account,
I receive messages (in my Outlook mailbox) from Microsoft or Google, telling that ReadyNas has been given access to my mailbox
But ReadyNAS is still unsuccessful at sending the test message ...
Best,
- schumakuMay 16, 2019Guru - Experienced User
So try the test from the shell ... by SSH ...
