gn00347026
Apr 05, 2017Guide
Rn104 panel shows - __del_reloc_root+2C
Hi there do anyone know what it means? Rn104 panel shows - __del_reloc_root+2C and it stop botting Thank you
- Apr 06, 2017
Yes, correct, that disk has a huge error count and it went offline already.
Luckly i can still access the data volume in read only mode to do the backup
Thanks mdgm~
btw can you do me a favour, i have send a PM, can you have a quick look?
mdgm-ntgr
Apr 06, 2017NETGEAR Employee Retired
That error message that showed on the LCD is a short part of a kernel error message relating to a crash during balancing.
That disk has a huge error count. That disk probably should have been replaced quite a long time ago. When you fail to replace bad disks that can cause problems with e.g. volume maintenance.
I'm confident if you look at smart_history.log you'll find that that the disk has probably been showing signs of impending failure for quite a long time.
gn00347026
Apr 06, 2017Guide
Thanks mdgm~
- mdgm-ntgrApr 06, 2017NETGEAR Employee Retired
Sure I replied to your PM. That other problem looks like a data recovery situation. It can be expensive and may not be successful.
- gn00347026Apr 06, 2017Guide
Thank you!!
