AlecSmith's avatar
AlecSmith
RN104 Raid-X disk 3 failed and disk 2 unknown. Please help
Hi All, I'm new here but would greatly appreciate a solution to this mess. I have a fully populated RN104 which has 4x ST4000VN000 drives. It was configured with RAID-X in 2015.  The firmware is ...
  • Marc_V's avatar
    Jan 30, 2019
    Hi AlecSmith
    Welcome to the Community!
    Your NAS had multiple disk failure that is why your volume got inactive. Disk 3 failed and since Disk 2 had an increasing error count it might have failed during that time as well. It's unfortunate that we weren't able to replace the disk at the time of failure.
    The best thing is to contact Support and purchase the Data Recovery service or if you plan on DIY, checking on ReCLAIMe might be a good idea. There are other applications used by the Community members that might be advised as well.
    I hope you can still recover most of the Data on the NAS. If it's a backup storage then original data should still be safe.
    Hope this helps!
    Regards
ProSupport for Business
