booboo59
Jul 25, 2016Apprentice
RN104 won't power up
My RN104 seems to have powered down overnight (maybe there was a power failure?) but this morning it wont power up. The LAN port is blinking with activity (from the shared switch) but nothing happen...
- Jul 30, 2016
Quick update, and to close the thread. I received the replacement RN104, and came with 6.2.0. Next steps:
1. Installed scratch disk, and allowed NAS to format and install firmware
2. Upgraded to 6.5.0
3. Powered down
4. Replaced scratch disk with my old disks
5. Powered back on, and all back to normal
6. Chassis informed me of 6.5.1 and upgraded.
Will be shipping the failed chassis on Monday. Thank you.
booboo59
I've now tested the power supply, and I've getting +12VDC on the 2 pins on the flat side, ground on the other 2. That seems to indicate an issue with the chassis?
- StephenBJul 25, 2016Guru - Experienced User
Try powering down, and removing the disks (labeling by slot). Then power up, and see what status you get from RAIDar.
- booboo59Jul 25, 2016Apprentice
Well, it's powered down already. But won't power up, regardless of having disks, etc. Already have hardware RMA filed, so will wait for the replacement unit. Thanks!
- JennCJul 26, 2016NETGEAR Employee Retired
Hello booboo59,
I checked your profile and found that you have already spoken with one of the support experts and have processed a replacement for your chassis.
Make sure you label the disks like what Stephen said. Once you receive the replacement chassis, put the disks back to their respective bays while NAS is off. Then power on the NAS and see if RAIDar will detect the NAS and access the files.
