pxg
Jan 15, 2016Aspirant
RN104 power supply
Hello
I have a rn104 but missing power supply. I can't copy data on new storage solution.
I don't find spare part reference on Netgear documentation.
Have you a corect reference for me or pin indication to find compatible model.
Regards.
- Hello I use a li shin 0129b1280 12V 6.67A on my RN104. The pin 1 and 2 (positive) are on the flat size of the connector (keyed size of the connector if you prefer) The RN104 work correctly Regards.
- JennCNETGEAR Employee Retired
- pxgAspirantThis NAS seems to old for valid warranty. I just want to buy a correct power supply for this material. Netgear documentation don't give the specifications for this power supply (external power with 4 pins connector) nor the pin assignation for alternate material (ie nas synology power supply). Regards
Hello pxg,
12V, 7A External 90W; input 100-240V AC, 50-60Hz
that is the specs of the power supply.
Pins or connector differ where the product is being sold or which country you bought it from.
- mdgm-ntgrNETGEAR Employee Retired
If your unit came without a power supply then you probably got it from a questionable source. The NAS may not be in a working condition.
- pxgAspirantThe external power supply was lost during the transport. This is actually suspiscious ? To summarize, I need an external power supply to hand the nas on the way and try to get back - if possible - the data. I thus need a corresponding and functional power supply. These characteristics are absent in the documentation and the pictures on the Internet are too indistinct to obtain this information (part number or pin assignation) without your help. Regards.
Ah, now it makes sense.
Hopefully the information that JennC provided helps.
- old1mikeAspirant
I have searched through the forums and googled. Did find 12v 7.5A 4-pin DIN 90W on ebay. Specs =
Input: AC 100-240V, 50-60Hz
Output: DC 12V 7.5APower: 90W
Connecter size: 4-Pin Tip
Title = 12V 7.5A New AC adapter power supply + cord for LI SHIN 0219B1280.
It would seem to fit the criteria BUT concerned about the connections.
Looked at some to the other links posted and power supply over $100.00 does not sit well with me.
This is photo from Ebay.
Would this work?
