pxg
Jan 15, 2016Aspirant
RN104 power supply
Hello I have a rn104 but missing power supply. I can't copy data on new storage solution. I don't find spare part reference on Netgear documentation. Have you a corect reference for me or ...
- Apr 30, 2016Hello I use a li shin 0129b1280 12V 6.67A on my RN104. The pin 1 and 2 (positive) are on the flat size of the connector (keyed size of the connector if you prefer) The RN104 work correctly Regards.
pxg
This NAS seems to old for valid warranty. I just want to buy a correct power supply for this material. Netgear documentation don't give the specifications for this power supply (external power with 4 pins connector) nor the pin assignation for alternate material (ie nas synology power supply). Regards
JennC
Jan 16, 2016NETGEAR Employee Retired
Hello pxg,
12V, 7A External 90W; input 100-240V AC, 50-60Hz
that is the specs of the power supply.
Pins or connector differ where the product is being sold or which country you bought it from.
