DiogoHC
Feb 05, 2020Guide
Power supply
I need a power supply for the Orbi RBS50Y that works in Portugal - 220v. The one that comes with the equipment is only rated for 100-120v
It will work on 240 volts. Ignore the label.
Been there, done that. You just need an adpter for US - Portugal sockets.
What's the model number On the adapter? AD2110F10?
More than a year on, it still works.
This product claims to work with RBS50Y and comes with suitable adapter. (How they do that is somewhat of a mystery.)
Basically, you want an adapter that provides 2.5amp at 12v output, with the same size plug as most Netgear products take.
- DiogoHCGuide
Thank you for your answer. The problem is that the RBS50Y is an outdoor equipment, and the original power supply has all kinds of protections against the elements - rain, dust, etc.
The one you mention should make it work, but without these protections - so it won’t work for me
Of course. I wasn't thinking. (Have virtually no outside electrical outlets! I drill through the wall to install almost everything!)
The Installation Guide (http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_QSG_EN.pdf ) says that the power adapter "varies by region". I realize this is not much help because Netgear doesn't sell power supplies as separate items.
Outdoor lighting is often 12v. Perhaps a visit to a local home center or landscape supply place?
If you don't have a use for the one you're using, i'd try plugging it in and seeing if it worked (in a safe spot). I know that many that are used in the EU only have rated to 120v on the plugs but work up to 220v. If you plug it in and test it and it works. yaaaa. If its not rated, it blows and potentially trips a breaker.
https://community.netgear.com/t5/Orbi/RBK20W-Power-Supply-Moving-US-to-Europe/td-p/1806838
plemans wrote:I know that many that are used in the EU only have rated to 120v on the plugs but work up to 220v. If you plug it in and test it and it works. yaaaa. If its not rated, it blows and potentially trips a breaker.
Or it will cause a fire. Good luck explaining your insurance company! In my opinion these advices here are criminal.
Of course e.g. Amazon will deliver US power supplies if people are going to order from online stores intended for other contients. Netgear does supply the correct power supplies to the distribution channels for each market.
schumaku wrote:
Netgear does supply the correct power supplies to the distribution channels for each market.This is great news. I have been wanting to purchase an "official" Netgear power supply for the RBS50Y. Can you post a link to the distribution channel that carries them in the US?
- DiogoHCGuide
michaelkenward wrote:
DiogoHC wrote:I need a power supply for the Orbi RBS50Y that works in Portugal - 220v. The one that comes with the equipment is only rated for 100-120v
Thanks for your help.
Actualy the model is AD10330LF, but I decided to give it a try on 220v and it works.
DiogoHC wrote:Actualy the model is AD10330LF, but I decided to give it a try on 220v and it works.
Great feedback. Very helpful. It could help someone who turns up here with the same issue.
It is puzzling that Netgear does not label adapters properly. Perhaps it is a legal thing in the USA.
