pxg
Jan 15, 2016Aspirant
RN104 power supply
Hello I have a rn104 but missing power supply. I can't copy data on new storage solution. I don't find spare part reference on Netgear documentation. Have you a corect reference for me or ...
- Apr 30, 2016Hello I use a li shin 0129b1280 12V 6.67A on my RN104. The pin 1 and 2 (positive) are on the flat size of the connector (keyed size of the connector if you prefer) The RN104 work correctly Regards.
JennC
Jan 15, 2016NETGEAR Employee Retired
pxg
Jan 16, 2016Aspirant
This NAS seems to old for valid warranty. I just want to buy a correct power supply for this material. Netgear documentation don't give the specifications for this power supply (external power with 4 pins connector) nor the pin assignation for alternate material (ie nas synology power supply). Regards
- JennCJan 16, 2016NETGEAR Employee Retired
Hello pxg,
12V, 7A External 90W; input 100-240V AC, 50-60Hz
that is the specs of the power supply.
Pins or connector differ where the product is being sold or which country you bought it from.
