Oz0ne
Jun 09, 2017Tutor
RN10400-100NAS won't power up, but power supply has green light
Hi all, My RN10400 recently stopped powering up. The power supply shows a green light, but the unit doesn't have any power. I don't know if I just need to replace the power supply or if there w...
Oz0ne
Jun 09, 2017Tutor
Great question. It is not connected to a UPS it is dirrectly connected to a wall socket.
Retired_Member wrote:In case it is connected to an UPS you might want to try connecting it directly to the wall instead.
Retired_Member
Jun 09, 2017Well, being paranoid, I would also try a different wall socket, if you have one in reach.
- Oz0neJun 10, 2017Tutor
Thanks for the suggestion. I tried a different outlet and that still didn't solve anything. guess I will try a new power supply
- Retired_MemberJun 11, 2017
Yup, that would be the next step. However, it could also be, that the power supply is fine, but the nas itself cannot use the power provided for whatever reason.
- StephenBJun 11, 2017Guru - Experienced User
You might want to check your warranty status - the 3 year warranty covers the power brick and the chassis.
