Rolyg60
Sep 12, 2019Aspirant
RN10400 Hangs after brief use firmware version 6.6.0
Hi everybody! Im hoping you have a solution to my issue. I recently dug my RN10400 it out of the cupboard, hoping to use the unit again. However I have had some problems with the unit, that...
Sep 12, 2019Guru - Experienced User
The best way to test the disk is to connect to a Windows PC (either sata or with a usb adapter/dock). Then test it with vendor tools (seagate or lifeguard).
Rolyg60
Sep 13, 2019Aspirant
Hi
Thanks for that they are 2 x 4 TB Western Digital survelaince drives, made in 2014. I have got the lifeguard software, once i get hold of a usb to sata converrter i will check them out.
Thanks
