doug714
Nov 30, 2020Aspirant
Rn202 Keeps going offline for 3 minutes
My RN202 keeps going offline for exactly 3 minutes. Running 6.10.3 Today it has done this 4 times. Ideas anyone?
Marc_V
Dec 06, 2020NETGEAR Employee Retired
Welcome to the Community!
It would be best if you can download the logs and check on status.logs or kernel.logs
I suspect a OOM (out of memory) issue. Are you running any apps?
If you are not comfortable reading the logs kindly send the full logs to me via PM.
HTH
doug714
Dec 06, 2020Aspirant
HTH
I have downloaded my logs and will send them to you via PM as I really don't know how to read them. The only app that is running is Plex Media server. Thanks for your help! Doug
- Mar 26, 2017Retired_Member
