hammackj
Sep 11, 2019Aspirant
RN204 Both NIC light up but it wont get a ip address
Hi, I have a RN 204 and when it boots up I can see the /data drive on the LCD etc but the 2 NIC on the back are solid 1 light each and will not get a ip address. Is there a way to restore the OS ...
hammackj
Sep 13, 2019Aspirant
Hi,
I have tried that but the app doesn't detected on the network nor does the LCD show an IP. I bought a new readynas and put the drives in it, i am able to boot up with my old config but it cannot seem to read the volume, but it says all 4 disks are green. When I boot up the old one I can see the volume but cannot access it via the network. =\
Any ideas?
Sep 13, 2019Guru - Experienced User
What model?
What LED status are you seeing on the router/switch Lan port?
Also try removing the disks (labeling by slot), and then boot up the NAS. Does RAIDar see it then?
- hammackjSep 13, 2019Aspirant
RN 204. The right lights on both NIC turn green the moment I plug power in(doesn't matter if a cable is present). The switch has no lights for the cable in question (new cables tried several). WIth no disks it still wouldn't get a IP.
I was able to get the drives to read and work in the new readynas i bought. I am guessing the networking died in the old one, I am going to try and factory reset it at somepoint and see if it works again. I recovered all my data at this point though.
Thanks for the help.
-Jacob
