jayedog
Jan 05, 2021Tutor
RN204 won't power on
Hi, My rn204 won't power on. I've tried removing all the hard drives but no luck either. I suspect it may be a power supply issue. Where can I find a replacement psu and are there any other thin...
Sandshark
Jan 06, 2021Sensei
Do be careful with the 4-pin supplies and make sure the one you buy is compatible with ReadyNAS. There are two pin-outs of the 4-pin DIN used by different manufacturers. For ReadyNAS. the poisitve pins are 1 & 2, which are on the keyed (flat) side of the connector.
jayedog
Jan 06, 2021Tutor
I tested it with a multimeter and the power supply appears to be dead.
ordered this on ebay so fingers crossed
