bluemonkey136
May 20, 2019Aspirant
RN2120 Extremely Slow Image Load Times
RN2120 is recently having some serious load times with images. This is used for manufacturing to save pictures of products. There is a folder for images created every day. I have 4 x 12tb IronWolfs i...
bluemonkey136
May 21, 2019Aspirant
I used NAS Tester v1.7, 400mb files on 5 iterations. It was just something I found people using to test on the forums here.
I have tried disconnecting one of the network cables, but I can't say I tried it for long. I need to retest this method.
I will pull the log files today and review them for packet loss. And I will replace all the network cables as they may be older than I thought. I am yet to run any sort of maintenance on the volumes. I was uncertain of the best practice for this or the length of time it would take as I only have about 36hours on the weekend of downtime to accomplish this.
So yesterday I removed one of the machines that was uploading images to this NAS and it was still slow. But today it seems to be running perfectly. Before removing this machine I was probably writing 26 images per minute to this NAS. Image files between 3 to 6 mb each. I wonder if it was still slow after disabling one machine that was uploading because the NAS had to catch up?
I am now writing only 10 images between 2.5-4mb each to it per minute and it seems to be running just fine. I am able to lookup images quickly, and I am having no issues writing them. Maybe it was just being loaded down too much?
May 21, 2019Guru - Experienced User
Great, that's useful, and the results are fairly easily duplicated.
Possibly. The RN2120 has a slower processor than the other rackmounts. It's possible that just rebooting it resolved the problem (perhaps a memory leak or something else was hurting performance).
That could be a problem, though the both the balance and the scrub can be canceled. The scrub time is similar to a resync.
