jkucukov
Feb 22, 2023Aspirant
RN2120 Full Disc Inactive Volumes
HI, Its been a while since I have gone and purged my 24/7 video recordings, as I went to check on my files I couldn't access the folders on the NAS anymore, I can still log in and navigate through th...
Feb 22, 2023Guru - Experienced User
jkucukov wrote:
I had no idea that the discs become inaccessible when full
They don't always, but running out of free space can result in the file system becoming corrupted.
It's not the only cause though - are you sure that the issue was a result of a full volume?
jkucukov wrote:
is there a way to access the drives to make space for further operation?
If you have a backup (or don't need the data), then the simplest path is to destroy the volume and re-create it.
If you need to offload data, you will probably need data recovery.
jkucukov
The performance status of all 4 discs appears healthy. Is it possible to go into read only mode to take out the important files first?
- SandsharkFeb 22, 2023Sensei
By definition, you cannot delete anything when in read-only mode. Have you even been able to boot to read-only mode?
- jkucukovFeb 22, 2023Aspirant
I haven't tried the boot menu yet, I was hoping to enter the read-only mode in an attempt to copy out the important files. Is it possible to get to the boot menu from the IP Admin page or do I have to physically be at the unit and go through the reset button sequence during boot up?
- StephenBFeb 23, 2023Guru - Experienced User
Read-only mode won't repair the file system, so it won't mount the inactive Volume(s). Therefore it won't help you offload data.
You say "Volumes" - if you were using the default X-RAID,then you'd only have one volume. Can you clarify what RAID mode you are using, and how many volumes you had?
