jkucukov
Feb 22, 2023Aspirant
RN2120 Full Disc Inactive Volumes
HI, Its been a while since I have gone and purged my 24/7 video recordings, as I went to check on my files I couldn't access the folders on the NAS anymore, I can still log in and navigate through th...
jkucukov
The performance status of all 4 discs appears healthy. Is it possible to go into read only mode to take out the important files first?
Sandshark
Feb 22, 2023Sensei
By definition, you cannot delete anything when in read-only mode. Have you even been able to boot to read-only mode?
- jkucukovFeb 22, 2023Aspirant
I haven't tried the boot menu yet, I was hoping to enter the read-only mode in an attempt to copy out the important files. Is it possible to get to the boot menu from the IP Admin page or do I have to physically be at the unit and go through the reset button sequence during boot up?
- StephenBFeb 23, 2023Guru - Experienced User
Read-only mode won't repair the file system, so it won't mount the inactive Volume(s). Therefore it won't help you offload data.
You say "Volumes" - if you were using the default X-RAID,then you'd only have one volume. Can you clarify what RAID mode you are using, and how many volumes you had?
- jkucukovFeb 23, 2023Aspirant
I was afraid of that, the only way to go about taking out the important data is with some sort of data recovery software. Its a shame that the NAS itself cannot be used for data recovery in this instance. Or at least not needing to get SATA expansion ports with cables.
The 4 drives are set up as RAID 5, I do see under the Volumes tab that the X-RAID is turned on.
The message that's shown when I log in to the Admin page shows "Remove inactive volumes to use the disk. Disk #1, 2, 3, 4" is probably where I got the volumes part
