raidmount00
Aug 11, 2023Aspirant
RN2120 kicking off drive while rebuilding: not enough operational devices
Hi all, my nas gave me an alert of a disconnected drive, magically reconnected on its own after less than a minute, so it started the rebuild on its own. Given the issue I decided to replace that...
Aug 11, 2023Guru - Experienced User
raidmount00 wrote:
is there any way to re-mount it without losing the array?
Yes if you are comfortable using ssh (the linux command line). We'd need some more information though - do you have the entire log zip file?
- raidmount00Aug 11, 2023Aspirant
No issues with SSH, I'm familiar with it, I'm not so familiar with the mdadm command though.
I just sent you a PM with the logs, let me know if you need anything else to analyze.
Thank you!
