Beaufort
Jan 20, 2024Aspirant
RN214 email alerts
Hello everyone, I continue to be stymied trying to configure the ReadyNAS to send email alerts using the gmail SMTP server Google no longer supports "less secure apps". In the past I was succes...
- Jan 20, 2024
Beaufort wrote:
Firmware 6.10.1.
There was a change related to this in 6.10.2. So maybe start with updating your firmware.
I suggest moving to 6.10.9
Beaufort
Bingo - that actually did it. Thank you very much!
The most recent firmware I can upload is 6.10.8 but this did the trick.
Choosing "sign in with google" now brings me to a google interface that asks me to confirm and allow the ReadyNAS to have access. The relevant parameters are then auto-filled and a test message can then be successfully sent.
I wish I could also get my old ReadyNAS NVX to also send email alerts but I suspect that functionality is no longer possible. It still works properly but I can access it through an old version of Chrome running on a XP virtual machine.
Jan 21, 2024Guru - Experienced User
Netgear neglected to put 6.10.9 on their "check for updates" server. But it does have some security updates, so you should manually install it. Upload the zip from the link I posted, and extract the img file. Then install it using the manual update control on system->settings->update.
- BeaufortJan 22, 2024Aspirant
Great - thanks again.
