hilgie
May 19, 2019Aspirant
RN214 fails to come back up after update to 6.10.0
Hi,
After I upgraded my RN21400 to the 6.10.0 firmsware it doesn't come up anymore. On the display it says 'Booting' and it stops at 92%. I can't loggin with Putty neither. If I ping the nas I ...
- May 19, 2019
hilgie wrote:
I have no idea why the subject is RN312. (Typo?). But it is a RN214.
Thx - I took the liberty of correcting the subject lines.
hilgie wrote:
I've tried the USB recovery FW, but this to no avail.
USB recovery will re-load the firmware install image into the NAS flash memory, but it generally won't reinstall the firmware on the disks.
hilgie wrote:
Does your reply also counts for the RN214 NAS?
Yes. Though it might not help, I think it's worth a try.
hilgie
Hi,
Cheers
hilgie
May 19, 2019Guru - Experienced User
- hilgieMay 27, 2019Aspirant
I see that a lot of ppl are having trouble with this firmnware version. Isn't there any formal support? I mean, if I download an official firmware upgrade I expect it to work properly. Now, the reason why I have a NAS with 16TB is to make sure all my data is safe. Howcome this is possible and why is there no Netgear support?
What if I can't restore the NAS fully? I will loose all my data? Such a bad publicity from NETGEAR...
- hilgieMay 28, 2019Aspirant
Ok, did a reinstall of the OS and this worked.
Tnx for the advice.
Still wondering why this can happen.
Cheers.
- StephenBMay 28, 2019Guru - Experienced User
Hard to say - I haven't seen much in the forums here that suggest a cause for this particular symptom with 6.10.0. Often there are issues related to apps (particulary third party ones).
It is a good idea to make sure your backup is up to date before you trigger the update.
