ADFX01A
May 30, 2019Aspirant
RN214 Firmware 6.10.1: Slow Transfer Speed
I recently setup an RN214 NAS with Firmware 6.10.1 using 4 WD SATA 8TB Drives in RAID 5 configuration. I started transferring large movie files onto the NAS via Windows Explorer, but was only gettin...
May 31, 2019Guru - Experienced User
Can you run a benchmark with NasTester? http://www.808.dk/?code-csharp-nas-performance
Also, is the PC connected with gigabit ethernet or with wifi?
It'd be helpful if you download the log zip file and post network_settings.log here. (cut and paste it into a post).
- ADFX01AMay 31, 2019Aspirant
Thanks for your assistance, but the problems seems to have fixed itself. My transfer speed has increased to 88mbps to 150mbps range.
