chuck2go
Mar 02, 2020Aspirant
RN214 is no longer accessible on my local home net
I've had my rn214 about a year without incident. Recently, the nas became inaccessible from any machine on my local home network. This includes (3) Windows 10, (1) Windows 7 and (1) XP machine. RAIDa...
Mar 03, 2020Guru - Experienced User
What LED status are you seeing on the ethernet LED on the NAS (and router LAN port)?
chuck2go
Mar 05, 2020Aspirant
Thanks for the reply - on the readynas I get (1) flashing green led and (1) steady green.It's connected to a switch which is directly connected to the router. Connection on switch is flashing green.
- StephenBMar 05, 2020Guru - Experienced User
Ok. And disconnecting/reconnecting the ethernet connection doesn't give you a valid IP address for your subnet?
