Suzanb's avatar
Suzanb
RN214 Mirror Raid
Hi
I have a nas RN214 .
I have 2 x 3TB and 2 x 6TB
I want to mirror the 2 x 3TB and also mirror the 2 x 6TB, separately, reading about it looks possible, has anyone done it successfully. Help would be appreciated.. I have all my data copied elsewhere at the moment. Moved it till could sort out my problem. I don't want a raid 5, which it seems to want to do. Prefer a mirror copy don't want to loose my data.
Thanks Suzan
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi Suzanb,
    Welcome to the Community!
    By default, the ReadyNAS uses X-RAID which automatically sets the volume to RAID 5 when it has 3 or 4 disks in it.
    Your volume setup is possible by switching your volume from X-RAID to FlexRAID and create two RAID 1 volumes for each pair of disks. You may do that by logging in to the NAS admin page then go to System > Volumes, then click the X-RAID button at the right side of the page. After confirming that you want to switch to FlexRAID, the X-RAID button indicator will turn gray.
    You will then delete the existing volume, then create two RAID 1 volumes for each pair of disks. For a detailed step on how to create the volume, you may check the page 35-36 of the user manual (https://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf).
  • StephenB's avatar
    By default you'd end up with a 4x3TB RAID-5 group concatenated with a 2x3TB RAID-1 group (in one volume).  That would give you a 12 TB volume with single redundancy.
    Your desired configuration would of course give you 9 TB total (between the two volumes).
    I would like to add that you really should maintain a backup, and not depend on the mirror.  RAID-1 has its benefits (simpler recovery is one of them).  But it's still not enough to keep your data safe.
    • Suzanb's avatar
      Suzanb
      Hi Stephen.
      That's what I had read about, but wanted to be sure had it righ, been a while since done anything like this. Thank you for confirming it for me.
      I do have three other separate backups, a little paranoid, I know, but I have files I do not want to loose.
      Just thought this system would enable me to add and access easily.
      Thanks again for your help.
      Regards Suzan
      • Sandshark's avatar
        Sandshark
        Sensei
        You don't need to delete the initial volume after switching to FlexRAID if you first initiallize with only one pair of drives then switch to FlexRAID before you add the other two.  The first two drives will be the primary volume, containing apps and user folders (if you use any).
ProSupport for Business
