richard-york
Jun 19, 2020Aspirant
RN214 NAS not shutting down with UPS power is low or zero
My UPS seems to have started having problems but it shown up a more serious challenge with my RN214 (on latest firmware) - it's not shutting down when the UPS level drops below the threshold. I've ha...
- Jun 21, 2020
Sandshark wrote:
StephenB wrote:
https://networkupstools.org/docs/user-manual.pdf wrote:
The exact behavior depends on the specific device, and is related to:
• battery.charge and battery.charge.low
• battery.runtime and battery.runtime.lowIt doesn't sound like it triggered by a particular UPS command (at least not in all cases).
Those are the things you can normally select to determine when the UPS will send the shut-down command.
Well, as I said the manual isn't very clear on tnis point. But my impression from the code is that the NUT software is first translating the UPS messages into it's own set of generic state parameters, and then monitoring that state. I think it then issues it's own shutdown command based on the state changes - at least for some UPS. But I decided against spending the time to figure out exactly what is was doing. There is quite a bit of vendor-specific code in it.
richard-york
Hi Stephen, yes I'll give that a go, thanks. I've tried to work out from the documentation what the "auto" level means in practice, very roughly, but there's no indication at all.
Richard.
Sandshark
Jun 20, 2020Sensei
richard-york wrote:I've tried to work out from the documentation what the "auto" level means in practice, very roughly, but there's no indication at all.
I think that "auto" means the point at which the UPS sends a shut-down command. On some NAS, that can be set using the manufacturer's proprietary software. It's normally retained after power-down, so you can set it using the software and a PC and then move the UPS to the NAS.
- StephenBJun 20, 2020Guru - Experienced User
The NUT documenation doesn't make it very clear, but it does suggest that it depends on the specific UPS model.
- SandsharkJun 20, 2020Sensei
- StephenBJun 21, 2020Guru - Experienced User
