Juiced
Apr 12, 2021Aspirant
RN214 replacement tray
Sorry for bringing up a small issue, but I'm trying to find out how I can go about ordering or replacing a disk tray for the RN214D42-100NES NAS system. Had my trays stacked on the table while repla...
- Apr 12, 2021
There is a plastic insert that can be removed (then you'd attach the disk using screws through the bottom of the tray). But I'm not sure if it's the insert that's damaged, or something else.
Juiced
Understood and ty. I thought it was only me having issues trying to find a replacement tray due to the lack of questions regarding it. Will hold on to see if the moderators jump into the conversation, but will keep the link available in case they don't. Want to get my NAS up and operational again as soon as possible so I can use the cloud features again, but I should have just allowed the hours needed to rebuild each drive one at a time instead of pulling them all at once and upgrading to all larger drives. The broken corner of the plastic piece on the end, it shouldn't be so much of an issue if you look at it but it does mess with the alignment and the drives stability when inserted.
