Leventh
Jun 15, 2020Apprentice
RN214 replacing hard disks
Dear All, I am using my ReadyNas RN214 with 3x2TB disks in Raid 0 mode (eg. 6TB) with no redundancy, so I want to replace them 2x6TB wd red series for upgrade. I have checked with RAID calcul...
- Jun 15, 2020
Since you have configured the 3 HDDs you have to RAID-0 then for you to be able to use X-RAID you will have to destroy the volume or do a factory reset and start from scratch.
You will have to backup all your data first, then turn off your NAS and replace/insert the new drives (2x6TB, 2x2TB). You can then perform a Factory reset from the Boot Menu.
https://kb.netgear.com/22891/How-do-I-access-the-boot-menu-on-my-ReadyNAS-104-204-214-or-314
This will reset the NAS and reformat the drives and be configured to X-RAID RAID5.
HTH
Jun 15, 2020Guru - Experienced User
My advice is to avoid the WD60EFAX, because it is an SMR drive. Get the older WD60EFRX, or move up to the 8 TB Reds (which use PMR).
SMR drives will give uneven performance with write speeds, and there are some scenarios where raid resync or expansion can be extremely slow.
Leventh wrote:(For existing data, I think I have to backup them to another storage, because of Raid 0 configuration)
Correct. Then insert all your drives, and do a factory default procedure via the boot menu. Reconfigure the NAS, and then restore your files from the backup.
