davidr1
May 10, 2021Luminary
RN21400-100AJS last power state
Hi, I've just bought a new Readynas RN21400-100AJS. I was under the impression this was supposed to remember the last power state if there was a power failure. Last week after the unit had been sh...
- May 14, 2021
davidr1 wrote:
As Netgear over here are out of stock on all NASs I'm not sure how I can get it exchanged. Amazon say they will but the price keeps
A less expensive approach would be to connect the NAS to a UPS (which I think is good practice anyway).
When the NAS is powered off, then the UPS will ensure that the NAS doesn't see a change in the input power. When the NAS is powered on, then it would shut down cleanly if the UPS battery runs out.
davidr1
May 13, 2021Luminary
My 212 behaves as per the manual ans StephenB says.
Methinks the 214 should also.
As Netgear over here are out of stock on all NASs I'm not sure how I can get it exchanged. Amazon say they will but the price keeps going up.
davidr
May 14, 2021Guru - Experienced User
