Retired_Member
Mar 24, 2021RN312 with 2xRJ45 switch ? +vlan setting deletion
Hi, my question (#1) is how works RN312 with two ethernet ports. I have insufficient number of ports on my router/switch. ReadyNAS unit is connected to router/switch using port 1, while port 2 i...
Mar 24, 2021Guru - Experienced User
Retired_Member wrote:
i mean does ReadyNAS unit behave like switch for these two ports?
No, it doesn't behave like a switch.
I think the best path is just to purchase an suitable switch - small unmanaged gigabit switches are really inexpensive.
Retired_Member
Jun 07, 2021So it would not be generally possible, to connect another device on LAN port 2 and create bridge mode somehow? I guess VLAN does not work like this (like bridge for 2 networks with same IP range)? But there is in IP address setting listing DHCP, so where from does it lease the DHCP address?
I am still experiencing problem with the VLAN deletion on unactive LAN port 2, where is currently no device connected (attached screenshot).
I have tried searching for "vlan" file, which results by list attached below, but i havent found any config file or so. Where is VLAN settings stored? I mean file name or file location. Please dont tell me i have to reinstall whole ReadyNAS OS for the one simple task. Thank you.
Screenshot URL: https://abload.de/img/clipboard03abkbw.jpg
root@NAS:/# find . -name vlan ./proc/1/task/1/net/vlan ./proc/1/net/vlan ./proc/2/task/2/net/vlan ./proc/2/net/vlan ./proc/3/task/3/net/vlan ./proc/3/net/vlan ./proc/5/task/5/net/vlan ./proc/5/net/vlan ./proc/7/task/7/net/vlan ./proc/7/net/vlan ./proc/8/task/8/net/vlan ./proc/8/net/vlan ./proc/9/task/9/net/vlan ./proc/9/net/vlan ./proc/10/task/10/net/vlan ./proc/10/net/vlan ./proc/11/task/11/net/vlan ./proc/11/net/vlan ./proc/12/task/12/net/vlan ./proc/12/net/vlan ./proc/13/task/13/net/vlan ./proc/13/net/vlan ./proc/15/task/15/net/vlan ./proc/15/net/vlan ./proc/16/task/16/net/vlan ./proc/16/net/vlan ./proc/17/task/17/net/vlan ./proc/17/net/vlan ./proc/18/task/18/net/vlan ./proc/18/net/vlan ./proc/20/task/20/net/vlan ./proc/20/net/vlan ./proc/21/task/21/net/vlan ./proc/21/net/vlan ./proc/22/task/22/net/vlan ./proc/22/net/vlan ./proc/23/task/23/net/vlan ./proc/23/net/vlan ./proc/25/task/25/net/vlan ./proc/25/net/vlan ./proc/26/task/26/net/vlan ./proc/26/net/vlan ./proc/27/task/27/net/vlan ./proc/27/net/vlan ./proc/30/task/30/net/vlan ./proc/30/net/vlan ./proc/391/task/391/net/vlan ./proc/391/net/vlan ./proc/392/task/392/net/vlan ./proc/392/net/vlan ./proc/394/task/394/net/vlan ./proc/394/net/vlan ./proc/395/task/395/net/vlan ./proc/395/net/vlan ./proc/397/task/397/net/vlan ./proc/397/net/vlan ./proc/533/task/533/net/vlan ./proc/533/net/vlan ./proc/636/task/636/net/vlan ./proc/636/net/vlan ./proc/664/task/664/net/vlan ./proc/664/net/vlan ./proc/665/task/665/net/vlan ./proc/665/net/vlan ./proc/741/task/741/net/vlan ./proc/741/net/vlan ./proc/754/task/754/net/vlan ./proc/754/net/vlan ./proc/760/task/760/net/vlan ./proc/760/net/vlan ./proc/796/task/796/net/vlan ./proc/796/net/vlan ./proc/816/task/816/net/vlan ./proc/816/net/vlan ./proc/835/task/835/net/vlan ./proc/835/net/vlan ./proc/838/task/838/net/vlan ./proc/838/net/vlan ./proc/841/task/841/net/vlan ./proc/841/net/vlan ./proc/844/task/844/net/vlan ./proc/844/net/vlan ./proc/847/task/847/net/vlan ./proc/847/net/vlan ./proc/850/task/850/net/vlan ./proc/850/net/vlan ./proc/853/task/853/net/vlan ./proc/853/net/vlan ./proc/856/task/856/net/vlan ./proc/856/net/vlan ./proc/881/task/881/net/vlan ./proc/881/net/vlan ./proc/904/task/904/net/vlan ./proc/904/net/vlan ./proc/906/task/906/net/vlan ./proc/906/net/vlan ./proc/909/task/909/net/vlan ./proc/909/net/vlan ./proc/910/task/910/net/vlan ./proc/910/net/vlan ./proc/913/task/913/net/vlan ./proc/913/net/vlan ./proc/914/task/914/net/vlan ./proc/914/net/vlan ./proc/916/task/916/net/vlan ./proc/916/net/vlan ./proc/918/task/918/net/vlan ./proc/918/net/vlan ./proc/921/task/921/net/vlan ./proc/921/net/vlan ./proc/922/task/922/net/vlan ./proc/922/net/vlan ./proc/925/task/925/net/vlan ./proc/925/net/vlan ./proc/926/task/926/net/vlan ./proc/926/net/vlan ./proc/930/task/930/net/vlan ./proc/930/net/vlan ./proc/931/task/931/net/vlan ./proc/931/net/vlan ./proc/932/task/932/net/vlan ./proc/932/net/vlan ./proc/933/task/933/net/vlan ./proc/933/net/vlan ./proc/934/task/934/net/vlan ./proc/934/net/vlan ./proc/954/task/954/net/vlan ./proc/954/net/vlan ./proc/956/task/956/net/vlan ./proc/956/net/vlan ./proc/958/task/958/net/vlan ./proc/958/net/vlan ./proc/959/task/959/net/vlan ./proc/959/net/vlan ./proc/1008/task/1008/net/vlan ./proc/1008/net/vlan ./proc/1012/task/1012/net/vlan ./proc/1012/net/vlan ./proc/1024/task/1024/net/vlan ./proc/1024/net/vlan ./proc/1049/task/1049/net/vlan ./proc/1049/net/vlan ./proc/1068/task/1068/net/vlan ./proc/1068/net/vlan ./proc/1075/task/1075/net/vlan ./proc/1075/net/vlan ./proc/1077/task/1077/net/vlan ./proc/1077/net/vlan ./proc/1173/task/1173/net/vlan ./proc/1173/net/vlan ./proc/1189/task/1189/net/vlan ./proc/1189/net/vlan ./proc/1192/task/1192/net/vlan ./proc/1192/net/vlan ./proc/1196/task/1196/net/vlan ./proc/1196/net/vlan ./proc/1197/task/1197/net/vlan ./proc/1197/net/vlan ./proc/1198/task/1198/net/vlan ./proc/1198/net/vlan ./proc/1202/task/1202/net/vlan ./proc/1202/net/vlan ./proc/1206/task/1206/net/vlan ./proc/1206/net/vlan ./proc/1207/task/1207/net/vlan ./proc/1207/net/vlan ./proc/1208/task/1208/net/vlan ./proc/1208/net/vlan ./proc/1212/task/1212/net/vlan ./proc/1212/net/vlan ./proc/1214/task/1214/net/vlan ./proc/1214/net/vlan ./proc/1215/task/1215/net/vlan ./proc/1215/net/vlan ./proc/1216/task/1216/net/vlan ./proc/1216/net/vlan ./proc/1217/task/1217/net/vlan ./proc/1217/net/vlan ./proc/1218/task/1218/net/vlan ./proc/1218/net/vlan ./proc/1219/task/1219/net/vlan ./proc/1219/net/vlan ./proc/1220/task/1220/net/vlan ./proc/1220/net/vlan ./proc/1221/task/1221/net/vlan ./proc/1221/net/vlan ./proc/1222/task/1222/net/vlan ./proc/1222/net/vlan ./proc/1223/task/1223/net/vlan ./proc/1223/net/vlan ./proc/1224/task/1224/net/vlan ./proc/1224/net/vlan ./proc/1225/task/1225/net/vlan ./proc/1225/net/vlan ./proc/1226/task/1226/net/vlan ./proc/1226/net/vlan ./proc/1227/task/1227/net/vlan ./proc/1227/net/vlan ./proc/1228/task/1228/net/vlan ./proc/1228/net/vlan ./proc/1229/task/1229/net/vlan ./proc/1229/net/vlan ./proc/1230/task/1230/net/vlan ./proc/1230/net/vlan ./proc/1231/task/1231/net/vlan ./proc/1231/net/vlan ./proc/1232/task/1232/net/vlan ./proc/1232/net/vlan ./proc/1233/task/1233/net/vlan ./proc/1233/net/vlan ./proc/1245/task/1245/net/vlan ./proc/1245/net/vlan ./proc/1248/task/1248/net/vlan ./proc/1248/net/vlan ./proc/1271/task/1271/net/vlan ./proc/1271/net/vlan ./proc/1273/task/1273/net/vlan ./proc/1273/net/vlan ./proc/1294/task/1294/net/vlan ./proc/1294/net/vlan ./proc/1309/task/1309/net/vlan ./proc/1309/net/vlan ./proc/1319/task/1319/net/vlan ./proc/1319/net/vlan ./proc/1320/task/1320/net/vlan ./proc/1320/net/vlan ./proc/1321/task/1321/net/vlan ./proc/1321/net/vlan ./proc/1340/task/1340/net/vlan ./proc/1340/net/vlan ./proc/1341/task/1341/net/vlan ./proc/1341/net/vlan ./proc/1342/task/1342/net/vlan ./proc/1342/net/vlan ./proc/1343/task/1343/net/vlan ./proc/1343/net/vlan ./proc/1344/task/1344/net/vlan ./proc/1344/net/vlan ./proc/1345/task/1345/net/vlan ./proc/1345/net/vlan ./proc/1346/task/1346/net/vlan ./proc/1346/net/vlan ./proc/1347/task/1347/net/vlan ./proc/1347/net/vlan ./proc/1348/task/1348/net/vlan ./proc/1348/net/vlan ./proc/1349/task/1349/net/vlan ./proc/1349/net/vlan ./proc/1350/task/1350/net/vlan ./proc/1350/net/vlan ./proc/1351/task/1351/net/vlan ./proc/1351/net/vlan ./proc/1352/task/1352/net/vlan ./proc/1352/net/vlan ./proc/1354/task/1354/net/vlan ./proc/1354/net/vlan ./proc/1355/task/1355/net/vlan ./proc/1355/net/vlan ./proc/1356/task/1356/net/vlan ./proc/1356/net/vlan ./proc/1357/task/1357/net/vlan ./proc/1357/net/vlan ./proc/1358/task/1358/net/vlan ./proc/1358/net/vlan ./proc/1359/task/1359/net/vlan ./proc/1359/net/vlan ./proc/2557/task/2557/net/vlan ./proc/2557/net/vlan ./proc/2558/task/2558/net/vlan ./proc/2558/net/vlan ./proc/2574/task/2574/net/vlan ./proc/2574/net/vlan ./proc/2575/task/2575/net/vlan ./proc/2575/task/2583/net/vlan ./proc/2575/net/vlan ./proc/2576/task/2576/net/vlan ./proc/2576/net/vlan ./proc/2578/task/2578/net/vlan ./proc/2578/net/vlan ./proc/2579/task/2579/net/vlan ./proc/2579/net/vlan ./proc/2584/task/2584/net/vlan ./proc/2584/net/vlan ./proc/2587/task/2587/net/vlan ./proc/2587/net/vlan ./proc/2588/task/2588/net/vlan ./proc/2588/task/2698/net/vlan ./proc/2588/net/vlan ./proc/2590/task/2590/net/vlan ./proc/2590/net/vlan ./proc/2591/task/2591/net/vlan ./proc/2591/net/vlan ./proc/2592/task/2592/net/vlan ./proc/2592/net/vlan ./proc/2623/task/2623/net/vlan ./proc/2623/net/vlan ./proc/2626/task/2626/net/vlan ./proc/2626/net/vlan ./proc/2629/task/2629/net/vlan ./proc/2629/net/vlan ./proc/2630/task/2630/net/vlan ./proc/2630/net/vlan ./proc/2634/task/2634/net/vlan ./proc/2634/net/vlan ./proc/2734/task/2734/net/vlan ./proc/2734/net/vlan ./proc/2805/task/2805/net/vlan ./proc/2805/net/vlan ./proc/2830/task/2830/net/vlan ./proc/2830/net/vlan ./proc/2835/task/2835/net/vlan ./proc/2835/task/2851/net/vlan ./proc/2835/task/2876/net/vlan ./proc/2835/task/2878/net/vlan ./proc/2835/task/2879/net/vlan ./proc/2835/task/2880/net/vlan ./proc/2835/task/2883/net/vlan ./proc/2835/task/2887/net/vlan ./proc/2835/task/2888/net/vlan ./proc/2835/task/2917/net/vlan ./proc/2835/task/2918/net/vlan ./proc/2835/task/2919/net/vlan ./proc/2835/task/2920/net/vlan ./proc/2835/task/2921/net/vlan ./proc/2835/task/2985/net/vlan ./proc/2835/task/3013/net/vlan ./proc/2835/task/3030/net/vlan ./proc/2835/task/3065/net/vlan ./proc/2835/task/3066/net/vlan ./proc/2835/task/3067/net/vlan ./proc/2835/task/3509/net/vlan ./proc/2835/task/3514/net/vlan ./proc/2835/task/3517/net/vlan ./proc/2835/task/3538/net/vlan ./proc/2835/task/3564/net/vlan ./proc/2835/task/3577/net/vlan ./proc/2835/task/3590/net/vlan ./proc/2835/task/3613/net/vlan ./proc/2835/task/3627/net/vlan ./proc/2835/task/3628/net/vlan ./proc/2835/task/3629/net/vlan ./proc/2835/task/3630/net/vlan ./proc/2835/task/3631/net/vlan ./proc/2835/task/3632/net/vlan ./proc/2835/task/3640/net/vlan ./proc/2835/task/3643/net/vlan ./proc/2835/task/3645/net/vlan ./proc/2835/task/3647/net/vlan ./proc/2835/task/3649/net/vlan ./proc/2835/task/3651/net/vlan ./proc/2835/task/3653/net/vlan ./proc/2835/task/3655/net/vlan ./proc/2835/task/3663/net/vlan ./proc/2835/task/3664/net/vlan ./proc/2835/task/3665/net/vlan ./proc/2835/task/4086/net/vlan ./proc/2835/task/4087/net/vlan ./proc/2835/task/4096/net/vlan ./proc/2835/task/4099/net/vlan ./proc/2835/task/4100/net/vlan ./proc/2835/task/4101/net/vlan ./proc/2835/task/4104/net/vlan ./proc/2835/task/4106/net/vlan ./proc/2835/task/4107/net/vlan ./proc/2835/task/4108/net/vlan ./proc/2835/task/4109/net/vlan ./proc/2835/task/4113/net/vlan ./proc/2835/task/4114/net/vlan ./proc/2835/task/4116/net/vlan ./proc/2835/task/4118/net/vlan ./proc/2835/task/4119/net/vlan ./proc/2835/task/4120/net/vlan ./proc/2835/task/4121/net/vlan ./proc/2835/task/4122/net/vlan ./proc/2835/task/4124/net/vlan ./proc/2835/task/4131/net/vlan ./proc/2835/task/4132/net/vlan ./proc/2835/task/4133/net/vlan ./proc/2835/task/4134/net/vlan ./proc/2835/task/4135/net/vlan ./proc/2835/task/4136/net/vlan ./proc/2835/task/4137/net/vlan ./proc/2835/task/4345/net/vlan ./proc/2835/task/4354/net/vlan ./proc/2835/task/4395/net/vlan ./proc/2835/task/4396/net/vlan ./proc/2835/task/4397/net/vlan ./proc/2835/task/5146/net/vlan ./proc/2835/task/7984/net/vlan ./proc/2835/task/7985/net/vlan ./proc/2835/task/7987/net/vlan ./proc/2835/task/7988/net/vlan ./proc/2835/net/vlan ./proc/2843/task/2843/net/vlan ./proc/2843/task/2856/net/vlan ./proc/2843/task/2866/net/vlan ./proc/2843/task/2867/net/vlan ./proc/2843/task/2868/net/vlan ./proc/2843/task/2884/net/vlan ./proc/2843/task/2885/net/vlan ./proc/2843/task/2886/net/vlan ./proc/2843/task/2890/net/vlan ./proc/2843/task/2891/net/vlan ./proc/2843/task/2892/net/vlan ./proc/2843/task/2893/net/vlan ./proc/2843/task/2894/net/vlan ./proc/2843/task/2895/net/vlan ./proc/2843/task/2896/net/vlan ./proc/2843/task/2897/net/vlan ./proc/2843/task/2898/net/vlan ./proc/2843/task/2899/net/vlan ./proc/2843/task/2900/net/vlan ./proc/2843/task/2901/net/vlan ./proc/2843/task/2902/net/vlan ./proc/2843/task/2903/net/vlan ./proc/2843/task/2904/net/vlan ./proc/2843/task/2905/net/vlan ./proc/2843/task/2906/net/vlan ./proc/2843/net/vlan ./proc/2853/task/2853/net/vlan ./proc/2853/net/vlan ./proc/2854/task/2854/net/vlan ./proc/2854/net/vlan ./proc/2864/task/2864/net/vlan ./proc/2864/task/2928/net/vlan ./proc/2864/task/2937/net/vlan ./proc/2864/task/3103/net/vlan ./proc/2864/task/3104/net/vlan ./proc/2864/task/3105/net/vlan ./proc/2864/task/3106/net/vlan ./proc/2864/task/3107/net/vlan ./proc/2864/task/3353/net/vlan ./proc/2864/task/3366/net/vlan ./proc/2864/task/3369/net/vlan ./proc/2864/task/3411/net/vlan ./proc/2864/task/3412/net/vlan ./proc/2864/task/3413/net/vlan ./proc/2864/task/3491/net/vlan ./proc/2864/net/vlan ./proc/3439/task/3439/net/vlan ./proc/3439/net/vlan ./proc/3447/task/3447/net/vlan ./proc/3447/net/vlan ./proc/3449/task/3449/net/vlan ./proc/3449/net/vlan ./proc/3450/task/3450/net/vlan ./proc/3450/net/vlan ./proc/3493/task/3493/net/vlan ./proc/3493/task/3500/net/vlan ./proc/3493/task/3501/net/vlan ./proc/3493/net/vlan ./proc/3516/task/3516/net/vlan ./proc/3516/task/3519/net/vlan ./proc/3516/task/3520/net/vlan ./proc/3516/task/3521/net/vlan ./proc/3516/task/3530/net/vlan ./proc/3516/task/3532/net/vlan ./proc/3516/task/3617/net/vlan ./proc/3516/task/3618/net/vlan ./proc/3516/task/3619/net/vlan ./proc/3516/task/3620/net/vlan ./proc/3516/task/3633/net/vlan ./proc/3516/task/3634/net/vlan ./proc/3516/task/3635/net/vlan ./proc/3516/task/3636/net/vlan ./proc/3516/task/3637/net/vlan ./proc/3516/task/3638/net/vlan ./proc/3516/task/3639/net/vlan ./proc/3516/task/3641/net/vlan ./proc/3516/task/3642/net/vlan ./proc/3516/task/3644/net/vlan ./proc/3516/task/3646/net/vlan ./proc/3516/task/3648/net/vlan ./proc/3516/task/3650/net/vlan ./proc/3516/task/3652/net/vlan ./proc/3516/task/3654/net/vlan ./proc/3516/task/3656/net/vlan ./proc/3516/task/4089/net/vlan ./proc/3516/task/4102/net/vlan ./proc/3516/task/4103/net/vlan ./proc/3516/task/4105/net/vlan ./proc/3516/task/4164/net/vlan ./proc/3516/task/4307/net/vlan ./proc/3516/task/4308/net/vlan ./proc/3516/task/4309/net/vlan ./proc/3516/task/4310/net/vlan ./proc/3516/task/4311/net/vlan ./proc/3516/task/4312/net/vlan ./proc/3516/task/4313/net/vlan ./proc/3516/task/4314/net/vlan ./proc/3516/task/4315/net/vlan ./proc/3516/task/4316/net/vlan ./proc/3516/task/4317/net/vlan ./proc/3516/task/4318/net/vlan ./proc/3516/task/4319/net/vlan ./proc/3516/task/4320/net/vlan ./proc/3516/task/4321/net/vlan ./proc/3516/task/4322/net/vlan ./proc/3516/task/4323/net/vlan ./proc/3516/task/4324/net/vlan ./proc/3516/task/4325/net/vlan ./proc/3516/task/4326/net/vlan ./proc/3516/task/4327/net/vlan ./proc/3516/task/4328/net/vlan ./proc/3516/task/4329/net/vlan ./proc/3516/task/4330/net/vlan ./proc/3516/task/4331/net/vlan ./proc/3516/task/4371/net/vlan ./proc/3516/task/4372/net/vlan ./proc/3516/task/4373/net/vlan ./proc/3516/task/4374/net/vlan ./proc/3516/task/4375/net/vlan ./proc/3516/task/4376/net/vlan ./proc/3516/task/4377/net/vlan ./proc/3516/task/4378/net/vlan ./proc/3516/task/4379/net/vlan ./proc/3516/task/4405/net/vlan ./proc/3516/task/4406/net/vlan ./proc/3516/task/4407/net/vlan ./proc/3516/task/4449/net/vlan ./proc/3516/task/7989/net/vlan ./proc/3516/task/7990/net/vlan ./proc/3516/task/7993/net/vlan ./proc/3516/task/7994/net/vlan ./proc/3516/task/7995/net/vlan ./proc/3516/task/7996/net/vlan ./proc/3516/net/vlan ./proc/3526/task/3526/net/vlan ./proc/3526/net/vlan ./proc/3557/task/3557/net/vlan ./proc/3557/net/vlan ./proc/3704/task/3704/net/vlan ./proc/3704/net/vlan ./proc/4183/task/4183/net/vlan ./proc/4183/net/vlan ./proc/4370/task/4370/net/vlan ./proc/4370/net/vlan ./proc/4456/task/4456/net/vlan ./proc/4456/net/vlan ./proc/4593/task/4593/net/vlan ./proc/4593/net/vlan ./proc/4627/task/4627/net/vlan ./proc/4627/net/vlan ./proc/5411/task/5411/net/vlan ./proc/5411/net/vlan ./proc/5712/task/5712/net/vlan ./proc/5712/net/vlan ./proc/5768/task/5768/net/vlan ./proc/5768/net/vlan ./proc/6606/task/6606/net/vlan ./proc/6606/net/vlan ./proc/6980/task/6980/net/vlan ./proc/6980/net/vlan ./proc/7211/task/7211/net/vlan ./proc/7211/net/vlan ./proc/7228/task/7228/net/vlan ./proc/7228/net/vlan ./proc/7351/task/7351/net/vlan ./proc/7351/net/vlan ./proc/7418/task/7418/net/vlan ./proc/7418/net/vlan ./proc/7554/task/7554/net/vlan ./proc/7554/net/vlan ./proc/7601/task/7601/net/vlan ./proc/7601/net/vlan ./proc/7673/task/7673/net/vlan ./proc/7673/net/vlan ./proc/7705/task/7705/net/vlan ./proc/7705/net/vlan ./proc/7762/task/7762/net/vlan ./proc/7762/net/vlan ./proc/8006/task/8006/net/vlan ./proc/8006/net/vlan ./proc/8007/task/8007/net/vlan ./proc/8007/net/vlan ./proc/8059/task/8059/net/vlan ./proc/8059/net/vlan ./proc/8080/task/8080/net/vlan ./proc/8080/net/vlan ./proc/8083/task/8083/net/vlan ./proc/8083/net/vlan ./proc/8355/task/8355/net/vlan ./proc/8355/task/8359/net/vlan ./proc/8355/task/8360/net/vlan ./proc/8355/task/8361/net/vlan ./proc/8355/task/8362/net/vlan ./proc/8355/task/8363/net/vlan ./proc/8355/task/8364/net/vlan ./proc/8355/net/vlan ./proc/8357/task/8357/net/vlan ./proc/8357/net/vlan ./proc/8457/task/8457/net/vlan ./proc/8457/net/vlan ./proc/8573/task/8573/net/vlan ./proc/8573/task/8584/net/vlan ./proc/8573/task/8585/net/vlan ./proc/8573/task/8586/net/vlan ./proc/8573/task/8587/net/vlan ./proc/8573/net/vlan ./proc/8588/task/8588/net/vlan ./proc/8588/net/vlan ./proc/8606/task/8606/net/vlan ./proc/8606/net/vlan ./proc/8734/task/8734/net/vlan ./proc/8734/net/vlan ./proc/8747/task/8747/net/vlan ./proc/8747/net/vlan
- Retired_MemberJun 07, 2021
Ok, so i have found file /etc/network/interfaces where was located vlan configuration. I have truncated the file to 0 bytes and voila, it works.
So now, it only remains the first part of my question to answer.
So it would not be generally possible, to connect another device on LAN port 2 and create bridge mode somehow? I guess VLAN does not work like this (like bridge for 2 networks with same IP range)? But there is in IP address setting listing DHCP option, so where from does it lease the DHCP address? If i would connect some device to the the LAN port 2, would it lease IP address from home network router, which is connected to my NAS server through LAN port 1?
Thank you in advance for your help.
- SandsharkJun 08, 2021Sensei
While creating bridges in Linux is possible, I don't know if the ReadyNAS OS has all the kernel modules and other tools to create one. But I don't see the value in bucket-brigading anything through the NAS instead of buying a <$20 switch.
- Retired_MemberJun 08, 2021
The difference is one box vs two boxes with another cables. Why not to use hardware, that ReadyNAS unit already has and could be capable of using, instead of buying another box for 20 dollars. So what is the purpose of the second 1Gbit port? Only network bonding to 2Gbit with routers, that support it? If i would think like that, i would not run mFi server, Pi-hole server and Teamspeak server on my ReadyNAS, but i would have something like 3 another Raspberry Pi boxes, and probably also 2 another switches, which is not very smart.
I would like to know what happens, if i connect another network device to port 2 of ReadNAS. Is it gonna lease IP from my home router?
