blondie4406
Nov 11, 2019Aspirant
RN31222D - 100 Blue power light flashing with no access
I have a ReadyNAS 3122D that the power light just blinks and cannot be found by RAIDar. I have tried both LAN ports and different cables. I have also tried with and without the drives installed. N...
Marc_V
Nov 12, 2019NETGEAR Employee Retired
Welcome to the Community!
With what you have tried, there really is a possibility that a hardware problem is present on your RN31222D. If you have the original receipt and it is under 5 years it would be best if you contact NETGEAR Support right away to request for RMA.
Regarding the disks and it's data provided that they are healthy, you can transfer them to a new NAS or have them connected to a PC and use third party recovery software like ReCLAIMe to recover your data.
HTH
Regards
- SandsharkNov 12, 2019Sensei
Can you get any response from the boot menu: How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312 ?
As for data recovery, not directly in Windows, but ReclaiMe software says it can: https://www.reclaime.com/ . You can download the demo version to see if it will be successful.
A Linux system with BTRFS installed could as well, though it's not an easy place to go if you are not already familiar with Linux.. And, of course, you can move them over to another OS6 based ReadyNAS.
- blondie4406Nov 13, 2019AspirantThanks for the information. The unit won't start in the boot menu either. Looks like the unit is dead. I'm going to purchase another compatible unit an put the drives in it. I can see the partitions on the drives but not read them so I have a little hope.
