blondie4406
Nov 11, 2019Aspirant
RN31222D - 100 Blue power light flashing with no access
I have a ReadyNAS 3122D that the power light just blinks and cannot be found by RAIDar. I have tried both LAN ports and different cables. I have also tried with and without the drives installed. N...
Sandshark
Nov 12, 2019Sensei
Can you get any response from the boot menu: How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312 ?
As for data recovery, not directly in Windows, but ReclaiMe software says it can: https://www.reclaime.com/ . You can download the demo version to see if it will be successful.
A Linux system with BTRFS installed could as well, though it's not an easy place to go if you are not already familiar with Linux.. And, of course, you can move them over to another OS6 based ReadyNAS.
blondie4406
Nov 13, 2019Aspirant
Thanks for the information. The unit won't start in the boot menu either. Looks like the unit is dead. I'm going to purchase another compatible unit an put the drives in it. I can see the partitions on the drives but not read them so I have a little hope.
