Casgrain's avatar
Casgrain
RN3138: cannot change IP/DNS setting
Hi,   Ok so we changed our DNS servers at our business so now I have to change them in the ReadyNAS. Obviously I log into the UI, go to the network tab, select the settings from the gear of the bon...
  • StephenB's avatar
    Jan 09, 2020
    Casgrain wrote:
    Did the OS reinstall but still no connectivity... either that doesn't reset the network stack or I did something wrong
    An OS reinstall will
    • set the network stack to use DHCP, MTU of 1500, with no bonding
    • set the admin password to password
    • turn off volume quota (which is on the volume settings wheel).
    Instructions are on pages 44-46 here: http://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS6_Rackmount_HWM_EN.pdf
ProSupport for Business
