daKlone
Jun 27, 2017Aspirant
RN314 - Mixing HDD Manufacturer?
Hi All, I've just had a HDD fail on my RN314 :( It had a full set of Seagate Constellation CS 3TB drives in it, but these are no longer available. What would be a suitable replacement? Do...
- Jun 27, 2017
What would be a suitable replacement? Do I need to stick to Seagate or does it not matter?
You don't need to stick with Seagate.
Seagate Ironwolf Pro and Western Digital Red Pro are both suitable and on the hardware compatibility list. Any enterprise drive should work though.
The hardware compatibility list is here: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
Jun 27, 2017Guru - Experienced User
daKlone
Great, thanks for the help (again!) Stephen :)
