alfb
Dec 22, 2016Aspirant
RN314 Capacity upgrade failure (Message "unfreeze_partials.isra.75+4d")
Dear Community, RN314 running OS 6.6 Had 4*2TB drives moving to 4*6TB drives on HCL. First three drives upgraded successfully, will include my notes below. Fourth drive appears to have complet...
- Dec 30, 2016
After a "reshape" kicked off by mdgm, the expected space is now available.
Case closed.
Thanks to JeenC, FramerV and especially mdgm.
alfb
Dec 23, 2016Aspirant
Thanks for your reply JennC.
I've had the RN314 since 2014, and I did in fact register it at the time. I've not corresponded since this attempt to upgrade the storage capacity.
I suppose this question should have been posted somewhere other that "New to ReadyNAS" but that's where it ended up.
Anyway, I no longer can get GUI access to the admin pages, and SSH does not respond any more so even expert guidance probably won't be able to do much for me.
There is still the somewhat regular sound of disks seeking so I am letting it run in hopes that it is finishing the vertical expansion before rebooting it.
Thanks for your interest.
Regards, Alf
JennC
Dec 23, 2016NETGEAR Employee Retired
Hello alfb,
Can you PM me the SN?
If you can access the shares via Windows explorer or CIFS/SMB, try backing up important data if you haven't.
- alfbDec 24, 2016Aspirant
JennC
PM sent to you yesterday.
Alf
This ReadyNAS 314 eventually became totally unaccessible. A reboot was successful but capacity was not where it was expected to be considering the ungraded drives.
I will start a new discussion in "Using you ReadyNAS' named "New drives not being fully utilized after upgrade".
Thanks JennC for your interest and help.
- JennCDec 26, 2016NETGEAR Employee Retired
Hello alfb,
Is it still showing up on the RAIDar app?
I checked the SN and it is registered right. That purchase date issue was fixed and the registration of the product was corrected and done in year 2014, everything seems right with regards to the registration of the product which also shows that it still has warranty for the hardware but the support warranty for Email, Chat and phone are already expired.
May i also ask how many disks are currently inserted, which ones are old and which ones are new. at which disk did it stop resynching?
