shift8
Aug 26, 2019Aspirant
RN314 Mixing Seagate Drives
Hi, My RN314 is populated with 4 x 4Tb Seagate ST4000VN000 drives. These drives were purchased and installed in 2014 and the system has worked very well over that time. Considering the age of the...
shift8
Aug 27, 2019Aspirant
OK. So there should be no problem mixing the ST4000VN000 and ST4000VN008 drives in the RN314 (RAID5) if I had to replace one of the existing drives in the near future. Is this correct?
Sandshark
Aug 27, 2019Sensei
Correct. But actually, you can mix drives of different brands as well. The OS will complain if the drives are in different rotational speed classes, but that's all it will do -- complain. And, of course, you'll get the overall performance of the slower one(s). The NAS does not typically use the entire drive when partitioning, and I'm fairly sure that's to insure there is no issue with another brand being just a bit too small when added to an existing array. Note that some "white lable" drives are an odd size, apparently having some sections "roped off" because of sector problems, so those could be hit-or-miss.
I have a set of WD Enterprise-level drives (5 year warranty) where two have failed just past the warranty period (one 2 months after, the other 6), and I'm replacing them with HGST's. No problems at all. Well, none due to the replacement -- I am unhappy with what seems an early loss of two highly rated (and expensive) drives.
